peterblesi
Hi all,
I'm changing the exhaust on a '79 CJ7 304 5.0L from headers to the original manifolds and Y pipe. On the passenger side I found the Y pipe cannot be pulled tight to the manifold because the manifold bolts are not threaded all the way. I do not have a manual, however, the '80 manual calls for a damper in this spot. It also seems if the damper or a spacer were between the manifold and the Y pipe, the exhaust pipe would line up better down to the muffler.
So, my question. Do I need the damper ? If a damper is needed, could someone explain what is needed to connect. Instead of the damper, could I use a spacer or something to takes it's place ? Or, would I be better off connecting the Y pipe to the manifold and stacking washers on the bolts ?
Thanks again for all your responses.
