Welcome to jeepz.com .
its likely the ignition coil has overheated . Check any wiring to'it and to the starter relay for signs of burned insulation which will indicate burned copper strands . The ignition module may have taken a hit as well . See if the grease that is supposed to be applied to its bottom side has dried up . Dielectric grease is not the best for ignition modules , it retains heat in the module . You'll,want something that pulls heat from the module . Heat sink compound ( like from radio shack ) is good . Wondering if the thermal pastes used for CPU to motherboard will work as well. Check reluctor and stator in the distributor for signs of discoloration which indicate overheating. Those are the parts that replaced the ignition points and condensers .
