The clutch will start slippping under load. You'll see a random spike in your RPM's with the pressure plate fully engaged (your foot is not on the pedal). Depending on what model Jeep you have, check that your linkage is not bound,bent or low on hyd. fluid, but these effects usually show up as difficult shifts and gear grinding.
