Can anyone offer any pointers or thoughts on converting a 99 Wrangler TJ to diesel?  I've read up on it a bit and it sounds possible.  Has anyone here done it?  I also read that Jeep was planning (pre-economical meltdown!) to offer a diesel engine upgrade kit for YJ/TJ, etc. using the same diesel engine they once offered in the Liberty.
At this point, I'm not terribly concerned about the cost. I know it will be expensive, so I don't need to be dissuaded on that point. I'm more curious to hear from some of you more experienced grease monkeys what I'd be getting myself into from a feasibility standpoint. Also, what kind of performance issues (good and bad) might I encounter? Finally, my primary goal is to fuel it with biodiesel as the fuel is readily accessible where I live.
FYI, my TJ is a 99 Sport w/ RE 5.5" Long Arm lift, D44s, ARB front and rear, 35" tires.
Thanks!
-Rob
Thanks!
-Rob
