Here’s the problem with my ’04 Grand Cherokee SE 4.0L: About a month or so ago it started getting difficult to start. Instead of firing immediately, it would turn over half a dozen or more cranks before firing. Then last Tuesday it wouldn’t start at all. That day I replaced the plugs, checked for spark (which was good), and assumed no fuel so I changed the regulated fuel filter; started right up. Next morning, it wouldn’t start again. I discovered that after priming multiple times (can hear the fuel pump prime when the key is turned on) and turning over for about a minute or so, it would start. It would run rough for a few seconds, then idle fine. At this point let me say that it never stalled or shut off while driving, never ran rough, and showed no loss of power.
Still assuming no fuel (and doing some on-line research read that it could be the check valve in the fuel pump), I replaced the fuel pump. A very expensive proposition, as you know. It ran fine when I got it back, but the next morning it was back to the same thing; crank and crank and crank to get it started. A fuel pressure gauge on the fuel rail shows in the mid 40s for psi once primed, and bounces around 60 psi while running. Thinking a possible bad injector, I pulled the plugs again to check for a fouled plug; nothing. After replacing the plugs it started a little easier the next few times, than back to the same thing. After a few tries it sounds like it wants to fire, does that a few times, and then eventually sputters a few times, then finally actually fires and starts.
I checked my battery with a multi-meter. It was showing about 12.1 volts a few minutes after turning off. Since that is a little low and the battery was 3 ½ years old and showing a little swelling around the positive terminal. I just replaced it because I had read that Jeeps don’t like low voltage and it was on its way out anyway; still no change. Even though it doesn’t stall, run rough, or lose power, could it be the Crank Position Sensor? From what I am reading, this sensor can cause multiple problems when going bad.
Anybody have any ideas or suggestions?
