Cross Member
85zebracherokee
I just rebuilt the transmission in my wifes 93 grand. Whenever i removed the cross member one of the nuts in the frame rail had broken the welds, so the nut just spun in the hole. I cut the bolt to remove the cross member. I was wondering if this has happened to anyone else, and if so what you did.
i have never had it happen to me but you might be able to buy these things, i call em' a nutcert, they go into a hole and when you crank the bolt into the nutcert it spreads out and locks it down, it is very hard to find them (at least around here it was.) but you can if you look hard enough. good luck bro. JOE>
