Dana 27 axle weakest points
bch-jeeper
What is the weakest part on the Dana 27 axle? What is the first part that usaly brakes?:bomb: The first part to go on mine was the spider gears. I put it under alot of force. by pulling a stuck buggy that was stuck on top of a raser back sand dune. I was on top of the dune. The buggy was jamed on a 60 degree raser back. I was only digging in deep into the sand. Then:bomb: spiders went. A guy with a 6000 pound Doge turbo dizel to yank it out.
closed knuckle shafts. Assuming you stick with a stock-ish motor, L head or F head, even locked with 34" tires, you will be fine.
I complied this table from an article in JP Magazine several years ago. From their notes and the measurements of various components you can see where problem areas may be. Hope this helps. Enjoy.
