OffRoadGeek
Hi, I bought a Dana 44 described as follows. "...rear axle Dana 44 out of Jeep Cherokee XJ. Some 1987-1989 Cherokees came from factory with this axle", "3.07 gears", "This Dana 44 is direct bolt-on for any Cherokee XJ. The only modification it might require, if any, is changing the length of the rear driveshaft. Shock mounts and spring perches are the same like in any other 1984-2001 Cherokee XJ. 5 on 4.5" bolt pattern and 60.5" wheel mounting surface (WMS) to WMS is also exactly the same like in Jeep Wrangler YJ and TJ and Grand Cherokee ZJ. So with few modifications (new shock, spring and Panhard rod mounts) it could be installed in any above mentioned Jeeps."
OK, the target jeep is my 94 YJ, 4.0L, 5sp, with a stock Dana 35, 3" body lift, extra leaf in springs (I think) and 3 or 4 inch shackles, 35" BFG M/T. It was recently hit hard in the rear destroying springs and shocks and maybe axle too. It is sitting in a good shop who will check frame etc. replace springs and probably the axle too. I don't have access to it, so I don't have a way to measure anything. While I was not planning to get hit, now is a good time to do the axle swap and am planning to do the axle prep outside the shop. What I don't know is, without the original axle in hand, how do I know where to move the shock and spring mounts on the 44 to fit my jeep. The shop can probably do it, but my dad was a production welder for many years and can do the job too and for free. yeah, and I think the 3.07 gears in the 44 are different than in my 35. Ideas on what I need to put in.
Any info or dimensions would be appreciated.
