dash lights
benjlever
newbie here again. Just tryin to get the CJ past inspection right now. Runs fine. Having problems with the dash lights. Namely left turn signal and high beam indicators. Assuming that they are burned out because right indicator works. how the *&%@ do i replace the bulbs? Do i actually have to dismantle my dash or do the connectors somehow detach from the back of the speedometer?
Also havin' trouble with my ignition. The starter is fine, it's the key that's giving my problems. it has a very hard time releasing and the ignition is very stiff. can i lube it up, or is it going to have to go? thanks alot. You guys have been great so far!
-Ben, '79 CJ7 3 speed manual[addsig]
1053235
I don't know about the lights but try graphite on the ignition cylinder[addsig]
