Allen's Offroad
Whether you want more safety for your daily driver or more offroad bite, this package offers the best of both worlds. With products from industry leading manufactures Eaton and Revolution Gear and Axle, you will have the confidence to take on any driving situation.
Click image to see online!
*Note: 5.38 ratio not available for D35 or 8.25 rear, AMC M20 4.10-4.88 only
Now you can get two great products to make your rig both a true daily driver and an offroading beast. Choose the ratio, axles, and other options to get you started on your chosen adventure!
Revolution Gears:
When you need a quality gear set - look no further than Revolution Gear & Axle. Revolution offers a full line of Premium, Top Quality Ring and Pinion gear sets in all the popular ratios to accommodate most light trucks, Jeeps and rear-wheel drive passenger cars. Revolution ring and pinion sets are constructed to last longer, run quieter and setup easier than other aftermarket gears. They do this by concentrating on every detail in the manufacturing processes of thier gears. From design, to final inspection Revolution’s attention to detail and precision guarantees that you’re getting the highest quality gear set available (Circle K stamped).
Click here for new ring and pinion break in procedure.
Detroit TrueTrac:
Lockers are Torsen style limited slip differentials that use helical gears instead of clutch packs to offer automatic torque biased traction to both drive wheels at all times. The ingenious design limits the speed of each wheel to 1.5 times faster or slower than the opposite wheel to provide full-time traction while still allowing for wheel speed differentiation in turns. The heavy duty all-gear design not only makes for quite and smooth operation, it requires no maintenance and will never weaken or wear out like a typical limited slip differential. These unique features make the Detroit TrueTrac ideal for race cars, rally cars, trail rigs, full size trucks, and daily drivers.
Installation Instructions
Revolution Gears:
Detroit TrueTrac:
