Hey guys I need some advice!! I have 82 Scrambler with a rebuilt 258. Got rid of all smog junk and wires and vacuume lines as well. I am running a comp cam with 450 lift inttake and I cant remember the exhaust lift and since I am not at home to check the spec sheet we will move on. I decked the head .030 and am running a motor craft 2100 carb. Engine only has about 500 miles on it but it is pushing oil up the distributer shaft and into the distributer housing. Not just a little but enough it runs out the hole in the botttom of the dizzy housing and onto everything under the hood. Anyone ever seen this before?? It is running 60lbs of oil pressure but that shouldn't matter I don't think.
