bradleyheathhays
Member
96 XJ here and my front doors have been tough to lock for a while now. It began about 10 years ago when something in the locking action became stiff and it took 2 pushes on the electric lock switch to get it locked or unlocked. It got worse over the years where it eventually took up to 5-6 pushes at which point I just started locking the doors by pushing the big rocker switch.
Thinking the lock actuators were failing I changed those out last year and learned a lesson. Problem still there.
So at this point I"m guessing it's the latches. I ruled them out before because I've sprayed tons of lube up into them and it didn't seem to help at all. Locking them using the rocker switch now takes a fairly good push with a stiff thumb. Locking and unlocking with a key is hard as well. If not the latch what else could it be?
