Allen's Offroad
Free Shipping in Lower 48 US only. CA residents add 7.25% sales tax.
The DV8 Offroad Rock Roller 2.5” Lift Kit was designed for those who want to gain additional ground clearance and accomodate 35” tires without compromising the factory ride. They accomplished this with longer springs and all of the necessary components to correct the suspension geometry for the lift. Add their unique shock extension kit or a set of DV8 Monotube shocks for increased articulation and a completely dialed in ride. Click the image below to order.
4 PATENT PENDING DV8 PROGRESSIVE RATE COIL SPRINGS
EXTENDED SWAY BAR ENDLINKS
BRAKE LINE EXTENSION BRACKETS
BUMPSTOP EXTENSIONS
2 DEG ALIGNMENT WASHERS
Install Instructions Here.
Features:
2.5 INCH LIFT KIT
CLEARS 35 INCH TIRES
EASY BOLT ON INSTALLATION
VEHICLE SPECIFIC SPRING RATES
STOCK DRIVE LINE COMPATIBLE
Add their DV8 Monotube Shocks! -Valved Specifically for the Jeep JK -Longer shocks equal more articulation -Large 2.2” shock body for less shock fade -Designed to work in hamrony with our spring rates for a better overall ride. - (Made by Eibach for DV8).
OR...
Add their shock extension kit! -Properly positions factory length shocks to work with a 2.5” lift (Re-use factory shocks!) Unique 1/4” brackets sandwich the factory mounts for more rigidity & less chance of bending compared to the competition -Hand milled billet alumium rear extensions
WHEN YOU CHOOSE ANY DV8 SUSPENSION KIT YOU CAN REST ASSURED THAT YOU ARE GETTING A QUALITY KIT THAT WORKS. MANY COMPETITORS SELL DISCOUNTED KITS THAT DONT INCLUDE ALL THE COMPONENTS THAT ARE NECESSARY TO CORRECT GEOMETRY AND MAKE THE JK PERFORM THE WAY IT SHOULD. WE BELIEVE THAT THIS IS NOT ONLY UNETHICAL BUT ALSO UNSAFE. THAT'S WHY WE ONLY SELL COMPLETE KITS. SO THAT YOU WILL BE JUST AS EXCITED TO DRIVE YOUR LIFTED JK AS YOU WERE THE DAY YOU DROVE IT OFF THE LOT. WE SUPPLY ALL THE NECESSARY COMPONENTS TO ENSURE THAT DRIVING YOUR MODIFIED JK IS ALWAYS FUN AND NEVER BECOMES A CHORE. THIS IS HOW WE DEVIATE FROM THE ORDINARY AND WHAT MAKES US DV8 OFFROAD.
BUMPSTOP EXTENSIONS
Features:
2.5 INCH LIFT KIT
OR...
