Allen's Offroad
Still great deals to be had on the Pro Rock Dana 44 by Dynatrac!
(normal truck freight in lower 48 states + applicable taxes).
I am a Dynatrac dealer and are offering the Pro Rock 44 to you either as a direct replacement for your factory D44 or as an upgrade from the D30.
Pro Rock 44 PDF here!
Standard specs:
* Complete custom Pro Rock 44 front axle housing with 12 month limited warranty
* Custom machined Dynatrac high ground clearance, high pinion (reverse-cut) heavy duty nodular iron housing
* Axle width 65.5†(stock JK) when outfitted w/stock wheel ends
* Standard housing geometry, pinion angle, and wheel alignment for customer’s suspension
* Uses new generation JK ring and pinion
* Dynatrac Pro Series nodular iron differential cover
* Dynatrac Jeep coil spring bracket set (Includes heavy duty brackets and installation, trac bar bracket & shock mounts included)
* Heavy Duty 3.0†X .313â€(5/16thâ€) wall DOM housing tube assemblies
* Dynatrac Pro Series extra strength end forgings w/ball joints installed
* Detailed and painted Dynatrac’s signature gloss black
Optional Installed Add-On Differentials - Complete w/Master Install Kit:
* Tru Trac heavy duty limited-slip differential w/R&P choice and 1310 yoke
* Detroit SofLocker differential w/R&P choice and 1310 yoke
* ARB Air Locker differential w/R&P choice and 1310 yoke
* Electric selectable locking differential (JK Tru Lok) w/R&P choice and 1310 yoke
Custom axle shaft mfg choices are numerous. If you want the RCV shafts, I sell those as well but you should run either the Pro Steer upper and factory lower ball joints or both factory joints.
PM for quote: (include any options wanted, shipping location and whether residence or business).
Thank you very much! I am grateful for your business.
Allen
