quicksand97
We carry throttle body spacers that outperform the competition. Our patent design delivers performance through out the whole RPM range from crawling to wide open throttle. Finally a spacer that works. Its has a smooth bore for smooth air transitions and its extended air blades keep your incoming air presurized without any air flow restrictions. Put that power and torque right where it counts, just under that throttle plate. We make spacers for 2.5L, 4.0L and 3.8L engines. We also carry 62mm and custom 68mm for stroker engines where intake manifold boring has been done. Or you 2.5L owners who run with bigger TB. Drop use a line at www.gsppowerspacers@aol.com or visi...imported/2011/09/goodpicofspacers-1.jpg[/img]
