Markinnevada
Well just when you guys thought the guy in Nev. couldn't be dumber that he was, here's another question. My book, and online research says my 83cj-7 has an icm, I'm thinking it's ignition control module. My jeep runs a bit rough even after replacing the usual, wires plugs cap rotor and mirrors( needed it anyway). My diag. book says to disconnect the orange and black wires from the icm, plug the vac advance and re-adjust the timing and idle screws. Problem is I can't find anything that remotely looks like a module. I have been all over the jeep. I have a little box next to the fuse block inside 2"x2", but it doesn't resemble any other module I've seen before. I've straightened out the hard starting, and most of the idle probs. but it still stalls when I put in gear. Thought maybe I should check the module unless someone tells me different. I'm also thinking about a new carb but it seems fine. Thought the icm might control the carb also since it has a relay type device plugged in the back. Cyborgish at best. Comments welcome ( about the Jeep)!!!
