1066677
Hi, This is a great board. Super information. We have two Cherokees. I drive a 94 Cherokee. My daughters is an 88 Cherokee (her 1st car). She wouldn't drive anything else. While adding refrigerant to the a/c system, I noticed antifreeze/water mixture starting to leak past the hose clamps on the coolant recovery tank. (88 Cherokee, 4.0. auto transmission) I noticed the electric fan, next to the mechanical fan for the radiator, was not blowing. I turned the motor off, she didn't blow. So the motor is overheating. I removed the electric fan and hooked up the wiring to my 94 Cherokee. The fan works OK. I replaced the " coolant fan switch ", I think this is the coolant temp sensor. Still no working fan. This Cherokee has all idiot lights, no gauges. I've had it about a year. No overheating problems until now. Is there a fuse or relay I could check. What have I overlooked? Thanks in advance.[addsig]
