On my 88 XJ the brown wire, at the plug at the bottom of the steering column, 12 gauge (medium big wire) supplies power to all these items at the fuse box. Turn your key to the run position (or probably the ACC. position) you should have power at the connector on the brown wire. If not, probably a faulty switch or broken wire or burnt contact at the connector.
Your 91 may be different. Check and see if all of your circuit breakers are plugged in all the way. My wife has a nasty habit of kicking the fuse box, the window wiper, circuit breaker, has fallen out on occasion. The 91 may have a circuit breaker for the circuit you mentioned, my 88 only has one for the wipers and the power windows that I´ve found.
