Engine for my yj
dodgetk81
I am new to this site, so I may be asking a question that has been asked many times but,
I have an 89 wrangler with no engine trans or x fer case. I am looking for guideance. I am a mopar man through & through so the 350 chevy is out. I was thinking about a 360 from a grand wagoneer. Would this drivetrain work? I would like to use the engine trans and x fer case as a unit. Has this or can this be done? My 2nd choice would be a 318 or 360 dodge engine. What are my choices for drivelines with the dodge engine. Thanks for the help.
Don
1040443
they used to put 401's in cj's why couldn't it be done. I've seen a 318 in a yj it's just as tight as a 350. The drive train can all be put in from another vehicle, you will just need custom drive shafts. Good luck and happy hunting..
1040450
At the shop I work at, we just got done putting a '99 5.2, from a grand cherokee into a 98 TJ. It fit kinda tight, but all in all it went in rather easily. I believe all the parts are readily available rither from parts houses or the dealer. We also used the trans. and trans case from the GC. That helped.
