First find out what code you havebyturning your key on and off three times and ending on on. Do not start the engine. Your codes could be read in the odometer. Followed by done.
Post up the codes.
To reset the code is easily just remove the positive terminal from your battery for 30sec. Some touch the pos connector to neg to draw any charge out. Personally I turn the key to on trying to start the engine with the terminal off to draw the charge out. The code should then be reset. If it reoccures within the next three starts there is a real issue.
