Engine swap
Probably not since the Cherokee is a unibody. You can put the motor in your wrangler though
Yep, same casting number on the blocks, they are identical. Just curious if I need to switch the actual mounting brackets themselves. Looking at the brown dog website it appeared anyways that there same bracket kits fit both applications, until you start adding headers and body lifts.
