I have a 93 Grand C.4.0L. I need to replace the o-ring on the oil filter housing. To remove the bolt thru the housing I need a hex bit, it looks to be about 3/4 inch. Does anyone know the exact size of the bit needed. Thanks.
It's a 19mm hex bit. What i have done in the past is buy a regular 90* hex wrench and place a small cheater pipe on the other end. If the short end is not short enough, cut it down to size.
