Oldchief
[TABLE="class: tborder, align: center"]
[TR]
[TD="class: alt1"]Get back to the boat ramp this afternoon and get the dreaded solenoid chatter when I go to crank up my '05 TJ:???:.
I know battery is good so check to see if I'd left any switches on, like the headlights or something. Nothing left on. I get a jump and make it home. Then I noticed the factory fog lights were on. Checked headlight switch and they were not turned on. Operated headlight switch in all positions; fog lights went off when I hit high beams but otherwise would not go off, no matter what position headlight switch was in. Went under the hood and pulled the fog lamp relay which finally killed fog lights. Any ideas? Would relay just go bad and keep fog lights on? Or, is it more likely a short in the headlight switch? Or??? Thanks for any help y'all can offer.
[/TD]
[/TR]
[TR]
[TD="class: alt2"]
[/TD]
[TD="class: alt1, align: right"] [/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[/TR]
[TR]
[TD="class: alt2"]
[/TD][TD="class: alt1, align: right"] [/TD]
[/TR]
[/TABLE]
