Beefy85CJ7
I've got a model 20 rear...the past owner threw in a one piece axle set and didn't grease the bearings (moron huh?) and well the whole outer end heated up, ground down and i got nothing!...since the bearings are aftermarket and unfindable...i temporarily rebuilt an old narrow m-20 with 2 piece, but a different gear ratio, to be able to take it out for a spin here and there...so no 4 wheel for now...but anyways...to the point i go...i've got a junk cherokee (87) with a good 44 on it...no idea of the gears but i'll figure it out...would this be a good solution? being it's already one piece, a stronger axle, and full width as is the front...and at the same time attempt a spring over since the springs mount on top of this axle anyway?...leaving me only a front spring wrap problem????possible???...highly confused in NY here...help...[addsig]
