P PS89YJ New member Mar 26, 2016 #1 I'm changing the front seals and have noticed small grooves in the axle shaft where the seals set. Question can I use a very fine emery cloth to smooth this out? Thanks Paul 89YJ
Bounty__Hunter Super Moderator Mar 26, 2016 #2 You can but once grooved it's likely to leak. Can be repaired with a ready-sleeve or just replace the shaft.
