One more rule of thumb, if the bleeder is on top, then i would assume that's the correct way along with the right or left markings on the caliper. Did you replace the calipers with new one's? . If you did, check the old one's and compare it to the new one and see if there is a difference in design. The brake hose where the banjo bolt attaches to the caliper can get flipped and cause it to be shorter, just a thought.
