89cherokee
I have an 89 cherokee with a 4.0 engine. I read several threads in the forum about fuel pressure and regulators. Here's my problem...the jeep would start and idle, but stall as soon as the gas pedal was touched. I hooked up the pressure gage to the connection and it read 28 PSI with the vacuum hose detached ...and 28 PSI with the regulator vacuum hose attached (it should have increased 8 psi) So I replaced the regulator...no change. I replaced the fuel filter earlier today. Could the fuel pump relay cause this? Or is the fuel pump the problem? Any suggestions would be greatly appreciated.
