brockchildress
The other day I went out and tried to start the jeep and it started up and then just died. Well I figured out its not getting gas. Changed the fuel filter, no luck. Changed the fuel pump and the pump relay and no luck. I can't hear the pump running when I turn the key on either. I left the pump out of the tank and turned the key and it came on so I thought it was good but I put the pump in the tank and I can't hear it running and theres no fuel pressure in the lines. I also tried the ballist resister trick by putting a jumper wire between them and no luck. I'm out of ideas. Any suggestions would help thanks.
