Allen's Offroad
Good day all.
I am offering the G2 Rear D44 assembly shipped in the lower 48 US for $2,238.00 with a Detroit Tru-Trac. This will accommodate your stock drum brakes from your Dana 35 rear. Upgrade today and enjoy peace of mind with those 35" tires and a locker.
Fully setup and ready to throw under your rig using your brakes. Includes 30 spline moly shafts, 1310 yoke, Aluminum cover, choice of 4.10~5.38.
Rear Axle Assemblies
Upgraded Dana 44 rear axle assemblies are built as direct bolt-in replacements for the stock Dana 35 found in Jeep TJs. Assembled with all new components, these assemblies are an easy swap to upgrade to a larger Dana 44. These housings are designed to accept the stock drum brakes, or can be upgraded to disc brakes as well.
Features
* Dual Bolt Pattern Axles to accept stock 5 on 4.5†wheels or 5 on 5.5†wheels
* Timken Bearings
* Gear ratios ranging from 4.10 to 5.38
* Heavy Duty Differential Cover
Available With
* Detroit Locker $2,288.00
* ARB Air Locker $2,445.00
* Detroit True Trac $2,238.00
(CA residents add 8.25% tax)
Lets do a front and rear package deal as well.
So, G2 D44s f/r with 4.56s, Tru-Trac lockers, moly shafts (inner/outer on front with joints), HD G2 cover, ball joints, setup and delivered using your brakes front and rear for $4499.00.
* Detroit Locker F/R $4604.00
* ARB Air Locker F/R $4913.00
PM me your name, billing and shipping address, phone number, email address (for PDF receipt) to order. I will call you for CC info.
Thank you very much. I am truly grateful for your business.
Namaste,
Allen
Features
* Timken Bearings
Available With
Namaste,
Allen
