GenRight Off Road
Here is a list with pictures of items we currently have on closeout.....these are limited items (in some cases only one) on close-out with all sales final.  Order now if you see something you like as we do not know how long they will remain on closeout!
Call Andrew, Closeout Sales Representative, at 805-584-8635! :beer:
VDP Super Siphon
The Patented Super Siphon is a self-priming siphoning device with 5 feet of hose. It is easy to use and eliminates the need to suck on the end of a hose to start siphoning. Great for transferring gasoline from a vehicle to a container or from a container to 4 x 4, Jet Ski, Motorcycle, etc. Moves 1.6 gallons per minute.
Factory TJ Hood
This is a mint condition factory Jeep TJ (or LJ) hood off a silver 2005 Jeep.
Key Features:
All Steel construction
Comes painted silver (paint code PSB)
This is a CLOSEOUT item and this offer is good for this one hood.
Factory gas tank and skid, 05-06 TJ/LJ
Used Factory Gas Tank and Skid, 05-06 TJ/LJ
This is a CLOSEOUT item and this offer is good while supplies last.
Jeep Tail Light, TJ
A single Jeep tail light for Stop, turn, and night lights. Originally off a Jeep TJ and a great spare or replacement for damaged lights so you don't get pulled over.
Savvy rear bumper w/2" receiver hitch, TJ/LJ
This is a Savvy Brand aluminum rear bumper for a Jeep TJ/LJ with a 2" receiver tow hitch.
It has been powder coated semi gloss black and is in perfect condition, as pictured.
It was a "take off" from a customer build here at GenRight.
Rugged Ridge chrome front bumper, TJ/LJ/YJ
This is a front bumper that will fit a Jeep TJ, LJ, or even YJ made by Rugged Ridge. It is made from a pair of large diameter tubes with another tube acting as a loop to protect your winch or grill.
Rugged Ridge rear bumper w/2" receiver hitch, TJ/LJ/YJ
This is a rear bumper that will fit a Jeep TJ, LJ, or even YJ. It has a mount with a 2" receiver tow hitch that attaches the chrome tube bumper to the Jeep.
TJ stock chrome step rails
A set of stock TJ chrome sliders. This is a great set to replace damaged TJ sliders or be a spare in case your offroad adventure becomes a little too treacherous. Each has a rubber step in the center to help as a step into the vehicle. The tubular construction holds up well when bashed against rocks or dips and they will not snag on rocks!
5 x 2013 take-off Rubicon wheels and tires
This is a set of (5) 2013 Jeep Wrangler JK RUBICON "take off" tires and wheels!
Tires: BF Goodrich Mud Terrain
Wheels: Jeep JK Rubicon 17"x 7.5" alloy wheels.
The stock Jeep Rims are in perfect condition and have only 13 miles on them!
The tires are new with the injection rubber "nipples" still on parts of the tire.
Standard Jeep JK bolt pattern, 5 on 5.
Full Race Currie Rock Jock 60 Front Axle
This is a slightly used full race Currie Rock Jock 60 front axle out of the 4485 Ultra4 race buggy. The unit was a back up unit and is "fresh" and ready to run! Over $10,000 invested in this top of the line front axle.
Hi-pinion Dana 60 front axle
5.13 gears, new
ARB locker, new
1350 yoke
300m axle shafts
CTM U-joints
Currie 4340 RACE unit bearing hubs with 5/8" studs (5 on 5.5)
Forged aluminum knuckles
Fully gusseted for strength
HD mounts for double triangulated 4 link suspension
Mounts for HOWE 2.25" full hydro ram
65" WMS to WMS
Designed to fit 13.8" brake rotors (brake calipers not included for this price)
Front JK D30 stock axle
Factory JK Dana 30 Front Axle. Was in perfect working order when removed. Complete with brakes and steering.
Factory JK D44 Rear Axle
Factory JK Dana 44 Rear Axle. Was in perfect working order when removed. Low original miles.
Complete with rear brakes and trac bar.
VDP Super Siphon
Factory TJ Hood
Key Features:
Jeep Tail Light, TJ
5.13 gears, new
ARB locker, new
1350 yoke
300m axle shafts
CTM U-joints
65" WMS to WMS
