GenRight Off Road
SPECIFICATIONS (more pictures below):
· 1997 Jeep Wrangler TJ
· 4.0L, 6cyl Engine, EFI
· 999 3-speed Automatic Transmission
· 231 Transfer Case with slip yoke eliminator and Tom Woods 2” diameter driveshafts with 1350 U-joints
· Currie Rock Jock Hi-pinion 60 Front axle with hi-steer knuckles.
· Currie Rock Jock Hi-pinion 60 Rear axle
· Yukon 5.38 axles gears and Detroit lockers, front & rear
· Stretched wheelbase (still seats 4 people) to 100"
· GenRight 4" Legend suspension kit with King Coil Over shocks
· GenRight belly up t-case skid plate
· Spector Cowl Induction Intake System (works like a snorkel)
· GenRight Full Aluminum Corners (CNR-5010)
· GenRight Mini Boat Side Rockers (RCG-5303)
· GenRight Aluminum Hi-Fender Tube fenders (TFF-2710 & TFR-1020)
· GenRight “Stealth” side marker light kit (LED-1004)
· GenRight Aluminum Swing Out tire carrier (RTC-3510)
· GenRight Stubby Front Bumper with Trail Stinger and built in winch plate (FBB-2200)
· GenRight CrMo Hi-Steer Kit with 7/8" heims (STK-8750) and our Twisted Pitman Arm (STK-2502)
· AGR power steering box and pump with hydro assist ram and 4 pass cooler
· GenRight full roll cage with all 6 points tied into the frame (GRC-4001)
· Factory ½ Doors with GenRight aluminum door armor (DSK-2000)
· WARN 8000 winch with roller fairlead
· MasterCraft Seats front and rear
· Magnaflow muffler with 2-1/4” exhaust (Cat back)
· Bestop SuperTop soft top
· DOT surface mounted LED tail lights (LED-1200)
· LED rock lights (LED-1206)
· 160W GenRight Rock Garden iPod sound system
· RaceLine Monster bead locks wheels, 17" x 9", 5 on 5.5 bolt pattern
· 38.5x17 Falken Wildpeak MT tires (Goodyears shown in pics)
· Height, Width, Length (74” x 82” x 161”)
· Weight: 4500lbs
· Rocker height 24”, T-case skid height 19”
· Approach & departure angle (70 degrees)
Asking orice is $54,999. Tony will be going to EJS and TDS in the coming weeks and can deliver Bowtie to those events for you.
If you have any questions or need any more info, please let me know. Best way to reach me is chrishatgenrightdotcom.
· Weight: 4500lbs
