Gone&DoneIt
I have been wrestling for months with pulling the 4 litre out, and dropping a Hemi in, putting a super charger on it or possibly nitrous, or a sm block v-8
I think I struck gold,... Golen Engines makes a monster 4.0 that I am pretty stoked about. I am planning to order it on the 14th of March. Anyone have one, or know anyone who does???
Jeep 4.6L / 260hp Long Block
Peak Horsepower: 260 bhp @ 5200 rpm
Peak Torque: 295lb/ft @ 4000 rpm
Operating Range: 1000 - 5200 rpm
Compression Ratio: 9:1
Required Fuel: 91+ Octane Pump Gasoline
Base Price: $3,499.00
*Late 1999 - 2006 Models add $200
If you’re thinking about buying a GES Jeep long block, be sure to check out the
“Jeep Facts†page for important information - Click Here.
Specifications:
Cam:
Block: Thermally cleaned and Stainless Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed
Crank: Peformance ground factory crankshaft, micro polished and oil holes chamfered
Rods: Jeep steel rods, shot peened for strength, resized with new performance ARP rod bolts.
Pistons: Speed-Pro hypereutectic, Coated Skirts
Rings: Speed Pro Plasma-Moly
Bearings: Clevite Main and Rod Bearings
Core Plugs: Brass Pioneer core plugs
Lifters: Comp Cams Hydraulic
Pushrods: SBI Performance
Rocker Arms: Factory Stamped Steel
Timing Set: Cloyes Performance
Oil Delivery: Melling high volume pump, pickup tube and HD Drive
Gasket Set: Fel-Pro Performance
Head Bolts: Factory
Manufacturer:
Comp Cams
Type:
Hydraulic Flat Tappet
Operating Range:
1000-5200 RPM
Idle Quality:
Good
Duration:
Intake: 210˚@ .050â€
Exhaust: 218˚@ .050â€
Lift:
Intake: .477â€
Exhaust: .493â€
Lobe Separation:
111˚
Heads:
Type:
Jeep factory iron, three angle valve job, bowl ported, valves back cut, new guides
Combustion Chamber:
62cc
Intake Runner:
155 cc
Intake Valves:
1.94 SBI Steel
Exhaust Valves:
1.50 SBI Steel
Optional Parts
62mm throttle body - 91-04 $350 05-06 $430 (sold outright)
24lb injectors - $375
Adjustable fuel pressure regulator 87-90 $255 or 91-95 $210
DUI Firepower ignition kit, includes cap, rotor, Screamin Demon Coil,
Livewire spark plug wires - $185
Specifications:
Cam:
Head Bolts: Factory
Manufacturer:
Comp Cams
Type:
Operating Range:
1000-5200 RPM
Idle Quality:
Good
Duration:
Lift:
Intake: .477â€
Exhaust: .493â€
Lobe Separation:
111˚
Heads:
Type:
Combustion Chamber:
62cc
Intake Runner:
155 cc
Intake Valves:
1.94 SBI Steel
Exhaust Valves:
1.50 SBI Steel
Optional Parts
