head gasket???
west747
Can anyone tell me if i can reuse the bolts for the vavle cover on an 258 I6??? i just want to change the head gasket as i am losing about a quart of oil and anit freeze pre day.... thanks for the input :-D :-D [addsig]
1054237
Sure you can so long as the heads are not stripped and the threads are good, just clean them up before you use them. :-) :-) :-) [addsig]
1054240
I´ve heard to keep them in order and check the lengths, putting a long bolt in the wrong hole can cause problems. Over tightening also causes problems. [addsig]
