1045045
Probably like the man said, the high beam relay is stuck or the high beam switch is broken.  Do you hear a klick when you try switching from low to high beam.  If yes, try pulling the relays one at a time and check to see if the high beams go out.  The high beam relay is either on the right fender well, inside the engine compatrment (under the cover) or on the left side fender well, up high.  Tried looking up the location, no luck.  Hope I helped a little.[addsig]
