With the engine temperature on cold. Disconnect both heater core lines from the engine compartment. Install a waterhose on one end then slowly open the faucet till the flow through the other end of the heater core is as much pressure as your pumping into it. If you have a lot of restrictions within the core, the flow will be poor and this may indicate a more thourough flush or replacement in the worse case scenario. A good indication of a clogged heater core is when you apply throttle, the heat output will increase and decrease at idle.
