Where to begin? If I understand what you are describing?...... First, I would check that I have power to the coil/distributor when the key is in the “ON” position. Next, check that you are actually getting fuel. Has your engine been converted to an electric fuel pump? If so, the symptoms you are describing are consistent with a wiring problem with the “N/O” circuit.
