My 95 jeep starts just fine i shift into reverse and it idles rough amd wants to die it is also doong rjis wjen i come to a stop on drive any help would be great
Check your connection at the TPS
Actuate the TPS 25-50 times with engine off by opening and closing the butterfly valve.
Clean the IAC and TB.
If you replace sensors use OEM
