Hello jeepz users,
I've had a problem with high idle for a few days now. I have replaced IAC valve, MAP sensor, and TPS. There for awhile it would idle anywhere between 1100 and 2000 if gas pedal is pressed and released it jumps to 3000 and stays there. I've checked for vacuum leaks and fuses even tested alternator and heard about low power steering could cause high idle. But it was full. So I drove it as is and it would eventually go into limp mode. Of course tried cutting it off and restarting but only for it to go a little farther and go limo mode again. I bought another IAC valve and it seems to work a little better but still getting high idle and limp mode is gone. Any help would be greatly appreciated. Really need fixed ASAP as it's the only form of transportation I have at the moment. Thanks.
2004 Jeep Grand Cherokee Columbia edition
4.0
4x4
4.0
4x4
