It's primary purpose is to help on powersteering demand at low idle situations when turning the steering wheel at idle. When working properly, at idle, turn the steering wheel and you will notice a slight surge on the engine rpm. This indicates that the pressure threshold on the required fluid flow is being compensated by the pump through a higher idle .
