JPNinPA
Well-known member
Ok I've been having issues with my home internet network. I've had the ISP out here several times. They ran a new cable to the house. But still every once in a while the Internet drops. Either you get booted off the router or the communication is interrupted. Game lag or slow page loading.
I've changed modems two times in three years and routers about the same. All are compatible with my ISP.
I replaced patch cables to CAT7 from the CAT5&6 I had.
Next is rewire the house cable with Quad foil RG6.
How often do you replace modems and routers?
Regards,
JPNinPA
Sent using TapTalk
Regards,
JPNinPA
Sent using TapTalk
