how to replace blubs in the speedometer
philip29
hey i got a 95 jeep cheorkee and my dash light in my cluster very din just need to know how to remove it and what kind of bulbs it takes. thank..
make sure its not your headlight switch. i had a similar problem and the headlight switch needed to be replaced.
If it is anything like the 01 Cherokee, then it's easy. Just slowly pull things apart and make a plan, before u unscrew any screw. The lights should be on the back of the cluster with a twist lock knob. Put LED's in.
