J-Daddy
OK, I found an '89 XJ I'm looking at and I was wanting to run it past you guys to see what you thought about the upgrades on it....
It's and automatic "4speed" with the 4.0 6 cylinder that's been rebuilt with about 40,000 miles on the rebuild.Seems to run really good & it drives good.
Here's the specs on it=
NP242 Transfer Case
Dana 35 rear end / Dana 30 front end w/3.73 Gears
Simpson 5 point harness on drivers seat
Rough Country 4.5" full leaf spring packs in rear
Daystar 1" extended greaseable shackles
Daystar 1.75" Poly Spacers in front
Rough Country long travel shocks
front extended loxer control arms w/poly bushings "not sure on brand"
poly bushings in leaf spring packs
Mickey Thompson Baja Claw tires 33x12.50r15"
15"x8" Rockcrawler Extreme Steel Series 152 Black Streetlock wheels "simulated beadlocks"
Bushwacker Cut-Out fender flares over trimmed fenders & quarter panels "looks factory & dang good"
1" transfer case drop
extended front sway bar extensions
Truck is solid, no rust or major dents, few small dings but nothing big...
interior is decent, needs a headliner though and the passenger side front door needs a new power window motor in it. It does have all the buttons and everything else works in it other than that one window motor is bad. The wheels and tires are almost brand new with no wear at all and all the suspension parts are only a couple months old.
What do you guys think it's worth? I can buy it for about $3500 or so I think.....That a decent buy? I'll try to attach some pics of it if they work.
NP242 Transfer Case
