Gone&DoneIt
Savage 25 Gas Powered RC Car with Extra's - $350
Reply to: sale-242484581@craigslist.org
Date: 2006-12-01, 1:13AM PST
First and Formost this truck is as close to brand new as you will find. It has 3 hours on it, and was professionally serviced two months ago. This is a great gas powered RC car, that is fast, capable, and fun. Over $700.00 invested, save 50% on a Car that has practically NEVER been run!!
The following is taken from the HPI Racing website:
The Savage 25 RTR is one of HPIs most powerful RTR trucks ever! This truck is a step up from the classic Savage 21 RTR and includes a more powerful S-25 engine, delivering 20% more power!
It takes the popular Savage to the next level, giving monster truck enthusiasts more power, higher speeds, and several extra exciting new option parts as standard equipment!
The heart of the Savage 25 is the powerful new Nitro Star S-25 that has 20% more displacement than the previous model. Its a .25 cubic inch (4.1cc) big block engine that features a billet aluminum heatsink head for extra cooling, dual bushing aluminum connecting rod, true ABC chrome sleeve construction for durability, and a simplified dual needle 7mm slide carburetor for easier tuning with a composite body for better performance at higher temperatures. The new S-25 is so powerful that we were able to gear the truck for higher top speeds, yet still retain excellent punch off the line. A high speed spur gear (49T) and larger clutchbell (15T) are now standard equipment, and we also include an 18 tooth clutchbell high speed on-road driving! Customers will immediately notice that the Savage 25 has more punch and higher top speed.
For added convenience we have added our convenient Roto Start System, eliminating the pullstarter from the engine! Owners will no longer have to worry about getting blisters from trying to start their engines - a press of the button and the engine roars to life! An added bonus of the Roto Start is that primer button on the fuel tank isnt needed, so we took it out to help reduce the possibility of air leaks. While we were revising the fuel tank we took the opportunity to move the fuel pick-up to the rear of the tank to help make the truck run more consistently through the entire tank of fuel. A ceramic in-tank fuel filter is now standard.
The buzz in the pits is that the Savage is the toughest and best handling monster truck on the market, but our R&D team set out to make it even better. To help handle the increased power we’ve gone to a heavy duty three-shoe clutch instead of the standard two-shoe design, which helps launch the truck harder under all conditions. Newly designed ribbed wheel hex hubs are now included to help cope with the increased power, gripping the wheel better to prevent stripped wheels. Stiffer shock springs are now standard, giving a flatter trajectory over large jumps and crisper performance when cornering at higher speeds.
The Savage 25 comes completely factory assembled; everything is done for the customer - even the tires are glued to the wheels. In less than 15 minutes customers can be driving their Savage 25 trucks! Based on requests from our RTR customers, we include a complete Instruction Manual that covers the entire assembly/disassembly process.
To top it off, we gave the Savage 25 a fresh new coat of paint. The wild red/silver/graphite graphics are sure to attract attention, and the entire body is completely ready to go right out of the box. Its painted, trimmed and decaled to look exactly like the truck on the front of the Savage 25 box.
Most of the chassis parts are carried over from the Savage 21, proven to be extremely durable and supported by a huge assortment of option parts from HPI and other manufacturers. The running changes to the Savage 25 were designed to maintain the excellent parts support already on the market, yet offer the customer a faster and more durable truck.
To wrap up the package, the Savage 25 is competitively priced. Even with the long list of added features â€" Roto Start, bigger engine, extra gearing â€" the street price for the truck will be around £75 more than the RTR Savage 21. Now is the time to place your orders, our initial shipments will
arrive in early October!
Features:
Nitro Star S-25 engine (ABC) with slide carburetor
Purple anodized, billet aluminum heatsink engine head
Roto Start System installed!
Aluminum high flow tube rear exhaust header
Stiff black shock springs
New rear pick-up 160cc fuel tank with no primer
Three-shoe clutch
Revised wheel hex hubs
Pre-painted trimmed GT-1 truck body in all-new colors with Savage 25 decals applied
Giant 1/8th scale (16.8" x 21")
Factory assembled
Full-time shaft driven four wheel drive
Complete set of rubber sealed ball bearings
TF-4 radio system with high torque steering servo
Composite tuned pipe and aluminum rear exhaust header
Cast aluminum heavy-duty engine mount
Heavy-duty drivetrain and suspension optimized for big-block engines
Hardened metal differential gears
Adjustable 2 speed transmission with heavy-duty metal internal gears
Adjustable slipper clutch
Adjustable disc brake
Wide-track suspension (nearly 17 inches wide!)
Stainless steel inboard hinge pins with anodized aluminum braces
8 long stroke oil-filled coilover shock absorbers
Rigid aluminum TVP chassis (Twin Vertical Plates)
Enclosed radio box for protection of electronics
Front and rear skidplate bumpers
Adjustable body posts (with extra mount for SUV bodies)
Chrome 5 spoke wheels and all-terrain tyres (with inner foam)
*Compatible with T-Maxx bodies
*Compatible with T-Maxx wheels
*Compatible with T-Maxx tires
--Optional reverse module for transmission (using the 3rd channel of the TF-4 radio system)
RTR Savage 21 RTR Savage 25
Engine 21BB Nitro Star S-25
Starting System Manual Pullstart Roto Start System
Spur Gear 52T 49T
Clutch Bell 14T 15T or 18T
Clutch Type Two Shoe Three Shoe
Shock Springs Red Medium Black Firm
Fuel Tank with primer, front pick-up without primer, rear pick-up
Body Black - Silver - Purple Red - Black - Silver -Gray
Size .21 .25
Horsepower @ RPM 2.3hp @ 30,000 2.5 @ 29,000
Maximum RPM 38,000
Heatsink Head cast metal Machined Aluminum
Case silver Black Heatsink Coating
Carburetor metal Composite
Carb Adjustments high, mid, low simplified to High and Low
Connecting Rod single bushing Dual Bushing
Construction ABC ABC
Features:
Three-shoe clutch
Factory assembled
Spur Gear 52T 49T
Size .21 .25
Maximum RPM 38,000
