Tug-n-pull
Today was an expensive yet good day! Thanks to all of you that took the time to make this an ez change out. I have a new slave cylinder in the bell houseing $134.00 New Penzoil Synromesh in the transmission, New ATF in the transfer, New Rear Output Seal in the transfer, New breather lines from the differeniales and the transfer case up in the engin compartment. Now for the first time I have a full pedal of clutch. It has been going for a long time. Had to hit at least 10 auto parts stores to get the syncromesh fluid, seal and slave. Local autozone only had 3 qt's to get started had to really look for the 4th. The dealer wanted $168.00 plus tax for the slave. There went my mod savings for a month or two. If I can just keep it together for a whaile I can get it lifted. Thansk again for the replys and help. Tug ;-) [addsig]
