bchcky
the need, for speed.
actually, i feel the need for my zj to stop bucking like i'm at a rodeo. i recently bought a set of TJ front axle shafts, and just threw them in my 96 zj this morning. pulled everything, put everything back in, even replaced the driver's side hub assembly while i was at it. hours later, i lower the jacks and stands, torque my wheels, and off i go.
first i get a little grinding sound, but i trace that back to the brakes just working themselves back into a groove on the rotors. BUT, then when i'm at full lock now, either right or left, it bucks like you wouldnt believe. ok, maybe its not that bad, but its definately not normal. i've replaced axle shafts before, and i've done hubs before, so i knew what i was doing, everything was put back together properly, and so on and so forth.
the difference now is that the shafts are u-joint shafts, where i used to have cv shafts, and i am now no longer running with tone rings, so i have no ABS, but all of this was pre-meditated, so it comes as no surprise. the difference i get now that i didnt plan on, and dont like, is the bucking. anybody have any clue at all? any and all suggestions are welcome. thanks in advance.
