O OhioMike New member May 13, 2005 #1 RE: ford in a cj? a crossmember for an 87 yj... somewhere close to dayton ohio would be great... it seems mine is rusted out where the transmission mounts and has been welded once already...
88Wrangles New member May 14, 2005 #4 RE: Oooops!!!!! jeepin916 said: do cj cross members fit? i have one to an 85 CJ7 Click to expand... They'd probably have different transmission's/t-cases, so the mounts would probably be wrong for the YJ....but I could be wrong. I'd try a wrecking yard. There should be a few there that aren't rusted out. Try this: http://www.valuparts.com/search.html
Bounty__Hunter Super Moderator May 14, 2005 #5 CJ crossmembers won't fit. Try www.car-part.com , see if that's any help. It can at least give you a ton of area junkyards to contact.
O OhioMike New member May 14, 2005 #7 i don;t have the resources to build...however it would be great if i did... thanks guys...i'll check out those sites...
