1056060
I have 8 rock lights installed on my 93 YJ. I've put one light in front and one behind each tire tucked up under the jeep. If you only have one light on one side of the tire, it casts too much of a shadow on the other side of the tire and you can't see what you're doing. The only problem I've had with mine is too much mud getting on them making them usless. If you can avoid it, don't install them in line with the tire or you'll get all the spray on them. There's also the problem of them filling with water. If they're cheap lights like mine, you might want to silicone them shut so they don't fill with water. I just used a couple of cheap sets of round reverse lights, they were about $10. each.
edited by: Craig, Feb 21, 2003 - 12:44 AM[addsig]
