installed trackbar relocation bracket - problems!!!
TwistedCU
I just installed the trackbar relocation bracket and now when I hit a speed bump at anything faster than a few MPH, I get a LOUD bang/clunk in the front end. I can't seem to figure where it is coming from.
It didn't do it before I put the bracket on.
The bracket was advertised for 3.5-4.5" lift. The coils I used are 3" lift coils.
before installing the bracket the front wheels were farther to the drivers side, now they are moved over to the Pass side, but not as bad.
I want to add an 1.25" by installing the coil spring spacers, but don't want to make it worse. Maybe it will correct it as the lift height will better suit the bracket?
Still I don't know what it is doing, but I am afraid to leave it for my commute tomorrow as it sounds real bad.
Maybe I should just remove the bracket?
Any ideas?
found the answer when I put the coil spacers on - the top of the driver's side swaybar link is hitting the coil. I need to get some longer links or better yet, disconnects.
