Jacobs Ignition - Key Switch Wire Help
rdiller
Quick question before I install my ignition system tonight...
I need to tie a wire into the switch for the ignition... I'm assuming this is just a wire that tells the unit that thekey is switched on. I'm going to put the control box on the drivers side, back corner of the engine compartment... Where is the best place to tie in?
97 TJ
Thanks for the help!
Ryan[addsig]
