Jeep CJ7 Clutch "Question"
Renegado
Hello, I have a CJ7 Jeep, some weeks ago I was having some problems with the clutch, most of all when it was stopped and as soon as I wanted to run it in first and trying to get out the clutch it started to vibrate a lot. Then I repaired the clutch using a new disc and also the flywheel and the cover assmebly were rectified and balanced but the problem persist. I want to know how can I solve the problem of this annoying hard vibration every time I want to start it in first gear. Thank You! [addsig]
1068202
Did you check out your pressure plate? If it gets warped it will cause it to shake especially when in first because you have to ease off the clutch.[addsig]
